Possibly buying my first OBS
Old Nov 12, 2014 | 10:05 AM
BBslider001's Avatar
BBslider001
Originally Posted by coreyallan01
I couldn't agree more Glenn.. My brother in law and I have a theory we can find at least one Macdonalds French fry in every used car....
Haha, man this is so true. For me, when I buy a vehicle, it is mandatory that the entire interior gets ripped out, power washed, and back together. It is amazing how much better they smell look when this is done.
Old Nov 12, 2014 | 12:03 PM
madMatador78's Avatar
madMatador78
Yeah i see plenty of thrashed vehicles come into three shop. When i bought the Subaru I swear i found enough dog hair under the back seat to make another dog.
To the OP, hope it all works out! These are great tucks. Let us know what else you find with r one you get it.
Old Nov 12, 2014 | 10:57 PM
BigRick1979's Avatar
BigRick1979
Well, I bought it. Talked him down to 3750. floor pans and cab mounts are in amazing condition considering the cab corners and box is toast. jacked up the front suspension leaf bushings are tight, and wheel bearings are good. found out that it has a built in exhaust brake. EBPV is sticking when under 40mph and when not on throttle. Idk if it is heads or valve covers that are leaking really bad.. I dont know how he thought it was a dipstick.... But my only concern is if it is the heads.. because according to the receipt the valve covers were just done. and just idling in driveway it will leave about a 2" puddle after 3 minutes.
. blow by there is none really considering mileage. shifts really smooth clutch feels great. turbo pedestal doesn't appear to be leaking.
Old Nov 12, 2014 | 11:46 PM
coreyallan01's Avatar
coreyallan01
What side is the puddle on? Could possibly be oil cooler if it's the drivers side... I'm not an expert by any means but I haven't heard of these heads puking oil like that...
Old Nov 13, 2014 | 11:57 AM
cowmilker08's Avatar
cowmilker08
Maybe one of the oil rail plugs on the back of the heads is leaking? The dipstick tube to pan adapter is a common leaker.
Old Nov 14, 2014 | 08:28 PM
BigRick1979
Sorry there are no updates. Been extremely busy with school and work. I'm hoping tomorrow to go pressure wash the whole undercarriage and engine compartment. So when unwell my 79 I can put it in my dads shop and stop tearing her down. If I need parts is riffraff still a good place. I'm just asking because I get a company discount at local bumper to bumper (Napa) but I was extremely pleades with riff rafts service and prices. But if the o-rings and gaskets are a higher quality I'll go with riff raff. But if they are stock o-rings I'll just go to local parts store.
Old Nov 14, 2014 | 09:51 PM
duck fan's Avatar
duck fan
Because racetruck
Riffraff uses Viton orings. Way better than stock. The products they manufacture are all made in the USA. You can't go wrong with them.
Old Nov 14, 2014 | 09:59 PM
madpogue's Avatar
madpogue
Found this, down this way in Baraboo - https://madison.craigslist.org/pts/4760551534.html - it's from an '86 though, so it might look out of place.
Old Nov 15, 2014 | 01:33 AM
BigRick1979
Wow you guys are the... Best. I will definitely use riffraff then. Just have to freeze my fishy off today and wash that sucker up.
Old Nov 15, 2014 | 01:37 AM
BigRick1979
I might even just rebuild cooler, filter housing, fuel lines for preventative maintenance.. ill most likely do the 6637 kit and throw out the k&n. As well as 3" body to get the 5" system. Is there anything else I should save for. Bellows d66? Oh and ihaven't decided I'd I should delete ebpv with a blank pedestal or wire it up for exhaust brake. I will be hauling wood on a 30' gooseneck.
Old Nov 15, 2014 | 06:14 AM
fordman67's Avatar
fordman67
To get a 3" dp in you don't need a porta power.just have to bend the lip down.a pry bar works just fine..I wouldn't do a body lift unless u need room for larger tires.
Old Nov 15, 2014 | 06:22 AM
BigRick1979
I just realized that I can't do a body lift because of gooseneck. Would be a secondary safety chain and rip my box off. As well as be a pain to raise and lower is an extra three inches.
Old Nov 15, 2014 | 09:54 AM
  #28
madpogue's Avatar
madpogue
Take out the "most likely". Dump that K&N ASAP; they let in too little air, too much dust. And you don't need a "kit", since you already have the tubing for the K&N. Just get the 6637 (or whatever the Baldwin / Donaldson equivalent is) and put it on the existing tubing in place of the K&N.
Old Nov 15, 2014 | 09:46 PM
  #29
madMatador78
^^^ x2 on this. My truck came with a K+N, t is a direct swap. Pry the most expensive intake system Out there. But I figure I didn't buy it, so no harm no foul. Lol.
Old Nov 15, 2014 | 10:07 PM
  #30
coreyallan01
I'd add that it'd be bennifical to use the 6637 equivalent that has the inner mesh.. I forget what it is off the top of my head..
EDIT: found it...
