Sponsored by: Auxito
wont start
Old Nov 9, 2014 | 06:24 PM
f150fanjr's Avatar
f150fanjr
Cool wont start
Hi All, I am new here. I will help when I can. And also would like help. I have a 1999 f150 4.2 2wd ext cap. Some times when I turn off the engine and then try to restart it, it will not start, but if I spray starting fluid in the intake it will start and keep running and I may be able to turn off and on and run it for a few days before it happens again. Any ideas? Thanks Jake
Also my code hook up does not work. No power there.
Old Nov 9, 2014 | 07:39 PM
Spotty's Avatar
Spotty
When is the last time you did a fuel filter? Check your fuses if the OBD port is dead. IIRC it is the same circuit as the cig. lighter.
Old Nov 9, 2014 | 11:32 PM
f150fanjr's Avatar
f150fanjr
Thank you I will check all the fuses tomorrow. I just bought the truck about a month ago.
Garr512
Oct 1, 2014 11:21 PM
Cheryl Rogers
57
Feb 19, 2014 02:15 PM
wrenchturner
13
Feb 12, 2007 06:56 PM
86F150-Lariet
30
Jul 19, 2006 01:37 PM
