EOT surpassing 300
Old Nov 8, 2014 | 02:09 PM
Pat Taugher's Avatar
Pat Taugher
EOT surpassing 300
Hi FTE, i just bought a Scan gauge 2, and inputted all of the codes to Xgauge.
One of them i added was EOT, when i first turned the truck on the EOT was -2.5. Then i drove about 2 miles to the local bagel place and it was at 305 EOT. I think i have a wrong code, because im guessing if i was surpassing 300F EOT, my truck would not be running correctly and most likeley have a CEL, and some other bad stuff. I pulled the dip stick and there was NO smoke and i could touch the oil with out burning my self.
Can i either get a correct code, or what is going on?
Thanks
Old Nov 8, 2014 | 02:14 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Try this one:
Engine Oil Temp
TXD: 07E0221310
RXF: 046245130610
RXD: 3010
MTH: 00090005F05F
Old Nov 8, 2014 | 03:01 PM
Pat Taugher
i will go check again, but im pretty sure that i have put that in
Old Nov 8, 2014 | 03:26 PM
Rusty Axlerod
I did find one alternate to try. The rest of the codes are the same but the MTH is 00090005FFD8 .
Old Nov 8, 2014 | 03:58 PM
Pat Taugher
Thanks let me try that.
Because there is no way i am getting 35-315 EOT's
Ill keep you updated
Old Nov 8, 2014 | 05:19 PM
69cj's Avatar
69cj
This is the one that works on my truck,
Old Nov 8, 2014 | 05:27 PM
Pat Taugher
So i figured out what was wrong, mix up where the 9 and 0 went. i think its working normally,
What should be my range between ECT and EOT?
on avarage it was from 185-205 ECT and 195-210 EOT
Those are when warmed up and driving around town it would fluctuate between there
Old Nov 8, 2014 | 05:51 PM
dannyboy950's Avatar
dannyboy950
Generally the delta is 15 degrees max with no load on flat ground with a fully warmed up enige driven between 15 and 20 miles normal driveing.
8 to 12 is considered good. Lower even better.
Old Nov 8, 2014 | 06:04 PM
69cj's Avatar
69cj
Thats at 60 to 65 mph no hills. Flat ground.
Old Nov 8, 2014 | 06:24 PM
dannyboy950
oooppppssss fergot the speed. Thks 69cj
Old Nov 8, 2014 | 06:32 PM
hasteranger's Avatar
hasteranger
What year? Apparently the early years won't necessarily throw codes for high eot. That's just what I read in a post about Ford updating the strategy for cooling hot engines a while ago. If your cooler was plugged, 300 degrees wouldn't be so hard to reach but the engine would probably be running pretty warm at that point too. And 300 degrees would be a stop driving the truck immediately type of temperature! So double check the codes and or try it on a friends truck.
Edit nevermind I guess I opened this thread a few hours ago so I didn't read the more recent replies.
10 degrees is normal around town with ac on. On a 50 degree or colder day, just normal driving, they should be within a few degrees of each other.
Old Nov 8, 2014 | 06:36 PM
69cj's Avatar
69cj
Spred means nothing driving around town with ac on unless you may be comparing past temps and then it's debatable.
Hence why you don't rely on factory gauges. They are basically useless unless you just want to know when things start to melt.
Old Nov 8, 2014 | 06:52 PM
dannyboy950
At 300 degrees his oil would not really be oil anymore it would flow right out of the bearings and he would shortly lock up.
Old Nov 8, 2014 | 06:58 PM
Misky6.0's Avatar
Misky6.0
Just to add, after sitting 18-24 hours the OIL, Coolant, and Trans temps should be within a few degrees of each other as well as the outside temp. Once the sun comes out and starts heating the ground/hood the temps would have more variation.. this would help you identify that -35 is wrong.
Old Nov 8, 2014 | 09:05 PM
hasteranger
I have no idea what you are saying or what point you are trying to make. The delta is important driving around town and whether ac is on or off is also relevant info. And neither he nor I are referring to factory gauges we are discussing the scan gauge 2.
