1978 - 1996 Big Bronco
banging underneath
Old Jul 17, 2003 | 06:41 AM
paul 123's Avatar
paul 123
banging underneath
Hello, I was wondering if anybody had this problem I'm having with my 93 bronco,For some reason when I back out of a parking lot or sometimes make a slow left or right turn there is banging coming from underneath of the truck, which seems to be right under my right foot or at least it seems to be coming from the front end.
Does anybody know what caues this? and how way to fix it
Thanks
Old Jul 17, 2003 | 10:20 AM
Kemicalburns's Avatar
Kemicalburns
banging underneath
could be the frontend needing some attention. Also you might pull your rear diff and inspect the gears. if your not to mechanical just take it to your local shop and have them check it out.
later
Old Jul 17, 2003 | 11:31 AM
BillyBob69's Avatar
BillyBob69
banging underneath
When you say banging, I am assuming you get 1 or 2 thumps that feel like its hitting against the floor. I agree with Kemical on the front end cjeck. I am about to put in new ball joints on my 85 and it does the same thing. On mine at least its the ball joints causing the prob. You can have those checked at any shop for the most part but if they do alignments, then its best to have them check it.
Old Jul 17, 2003 | 02:22 PM
AlM's Avatar
AlM
banging underneath
Yo; have you inspected the radius arm bushing(s)?
and...
Ditto on the ball joints as Kem BB advised; so here are 2 related TSB's:
Frame Rivet TSB 97-4-7
http://www.diesel-central.com/Tech/ford/docs/97-4-7.doc
and;
Ball Joint Clunk-Early Wear TSB 96-23-15
http://www.diesel-central.com/Tech/...cs/96-23-15.doc
Old Jul 17, 2003 | 03:14 PM
Sudsrat's Avatar
Sudsrat
banging underneath
I'll chime in.Had the same knocks-ball joints.
Old Jul 18, 2003 | 12:15 AM
steve83's Avatar
steve83
banging underneath
Check the pivot bolts carefully - if they were EVER loose, the could have slotted their holes. That's what mine is.
