What weight oil?
Old Jul 17, 2003 | 06:34 AM
midnightride's Avatar
midnightride
What weight oil?
I have a 1987 full size Bronco with a 355 L/S rear, what weight oil should i be using. Would the front axle be the same?
Old Jul 17, 2003 | 08:58 AM
jim henderson's Avatar
jim henderson
What weight oil?
Check the manual to be sure. Some of the diffs front or rear may use Auto Tranny Fluid.
Most rear diffs will work with 75W90 or if you run in high temps and tow you might go 90W140. With syn just stick with 75W90. You will also need one maybe two tubes of limited slip additive.
Good Luck,
Jim Henderson
Old Jul 20, 2003 | 08:46 PM
wildjon300ci's Avatar
wildjon300ci
What weight oil?
I normally put in Semi Syn 80W90
Is this good or not?
Old Jul 21, 2003 | 12:49 PM
jim henderson
What weight oil?
If the semisyn meets spec it will probably work. Also check for Limited Slip compatibility if that is an issue.
I tend to lean away from semi syn since they charge closer to the syn price but they usually cost the maker closer to the dino price to make. So I feel the semisyn is more of a marketing ploy to get more $ for something that is only a llittle syn. If you are going to pay almost syn price, might as well go syn.
Good Luck,
Jim Henderson
