Engine code for a 351W in a E150
Old Nov 7, 2014 | 11:25 PM
Oz Econoline's Avatar
Oz Econoline
Hi Guys,
I'm trying to find out the engine codes for a 1985 Econoline.
I'm looking at a E150 in California that the owner has said it has a 351W in it and I would like to find out the engine codes in chassis/tag to check which engine it was built with.
Would appreciate any help or directions to the right website to check.
Thanks Darin
Old Nov 8, 2014 | 01:47 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1985 E150 available engines: 300 I-6 (4.9L); 302 (5.0L); 351W (5.8L).
1981 thru today: The 8th digit of the VIN is the engine code.
G = 1980/85 351W 2V / H = 1985/89 351W 4V
Old Nov 8, 2014 | 02:50 AM
Oz Econoline
351w Engine codes
Thanks Bill! When the guy gets back to me with the info on the van I can check the number / letters you've given me and verify that it has a factory 351 Windsor.
Old Nov 8, 2014 | 02:53 AM
Oz Econoline
Thanks Bill! When the guy gets back to me with the info on the van I can check the number / letters you've given me and verify that it has a factory 351 Windsor. Do you have any of the additional information on the rest of the 17 digit chassis number or can you direct me to a website that'll give me that information? Cheers!
Old Nov 8, 2014 | 03:40 AM
NumberDummy
Post the VIN (before 11/12 .. I won't be here afterwards until 12/5) and I'll decode it for you.
There will be additional codes on the Certification Label (located [glued] on the left door face below the latch) for color, trans, axle and etc.
Old Nov 8, 2014 | 04:40 AM
Oz Econoline
Thanks Bill as soon as I get that info from the guy selling the van I will post the chassis number and the door label info if he supplys it . The 11/12 does this mine you will be off the forum from the 12 day of November till the 5 th day of December Thanks Darin
Old Nov 8, 2014 | 11:24 AM
NumberDummy
The 11/12 does this mean you will be off the forum from the 12 day of November till the 5th day of December?
11/12 - Flying from LAX to Fort Lauderdale FL .. 21 day Caribbean cruise begins the next day, ends 12/4. Then we have to fly back to LAX
Old Nov 8, 2014 | 02:40 PM
Oz Econoline
Sounds good hope you have a great time on your cruise and I will post the vin /chassis numbers as soon as he gets them to me .
williamsportwrestler
26
Sep 24, 2009 04:05 PM
DRagonBender
Nov 23, 2006 08:59 PM
Semperfi45601
1978 - 1996 Big Bronco
Sep 14, 2004 12:56 PM
tm winchester
Jan 1, 2004 09:48 AM
