Extra Battery Bracket
Old Nov 5, 2014 | 11:38 PM
wileycam2000's Avatar
wileycam2000
Does anyone know of where to get an extra battery bracket for the E-Series?? Looking to mount a second battery under the hood!!!
Thanks!
Old Nov 7, 2014 | 06:22 PM
blageurt's Avatar
blageurt
You can buy them from Ford.......Or a Junkyard....Ford Moved one Battery to the frame in 97....My Model and 96 was the last one to have 2 Batteries in the Front ( 7.3 Powerstroke Diesel)....the After that , the 6.0 PSD moved Both Batteries to the Frame rails...
Old Nov 8, 2014 | 09:39 AM
turbogus's Avatar
turbogus
Not only did Ford put plural batteries in their vans but also in pickups so if you go to the boneyard you're likely to find more pickups than vans~hopefully this'll broaden your search area.
Old Nov 8, 2014 | 09:24 PM
wileycam2000
Cool - Thanks! I am a little skeptical about putting one against the frame rails.... Seems like a sketchy place?? I off road a lot, so that is why... Gets dirty down there.. But Maybe it would be fine.
Old Nov 9, 2014 | 10:43 PM
baddad457's Avatar
baddad457
I put an extra battery in my 96, all it needed was a piece of plywood to set the battery on. The size of the deep cycle itself prevents it from moving anywhere. Fits like a glove. Just needed cables run over to the other side.
Old Nov 13, 2014 | 10:46 AM
Island Time's Avatar
Island Time
When I installed extra batteries in my '09 E250 a buddy and I fabricated a platform that mounts inside the frame rail on the driver's side. There was room to comfortably fit two group 31 batteries. I used AGM since checking or adding fluid would be a major pain.
The forward end of the platform has a heavy duty hinge with the back end secured with a hinged bolt assembly. The bolt end is back up with a heavy duty safety chain, just in case. The hinged feature makes it comparatively easy to get to the batteries, but it still requires a hoist.
The battery cables come up at the forward end where the hinge is. In my case it is a cargo van with a headache cage. The cables come up just forward of the headache cage where they land to a battery switch, fuses, etc. I know it isn't a Ford sanctioned solution, but it's been in place for two years with no problems. Here on island we have a mix of good paved, good unpaved, and just plain nasty unpaved, so the installation doesn't lead a pampered highway only life.
Batteries are like many things in life; you can't have too many.
Old Nov 13, 2014 | 03:14 PM
wileycam2000
Jim,
Looks like a fun project! Heading to a boneyard now to see what i can find!
Brad Brown
Feb 12, 2017 10:30 AM
lutarious
Dec 6, 2016 01:27 PM
DavenTn
Mar 29, 2015 07:05 PM
BadDogKuzz
Nov 17, 2014 01:28 PM
jh2oman
Dec 11, 2005 02:20 PM
