2002 3.0 intermittent bogging down
Old Nov 5, 2014 | 12:14 PM
nickmobile67's Avatar
nickmobile67
I just bought this truck last week. It has 55k on it, so I'm guessing it sat a lot. It seems to run great, but today on my drive to work it started having an intermittent bogging down when accelerating. It didn't seem to matter if I was accelerating soft or harder, or what rpm I'm at. It also did it when it was cold pulling off of my street and it did it once or twice after 15-20 minutes of driving. It just feels like I let off the gas for a moment, I can watch the tach drop about 500 rpm and then just as quick it picks right back up and is fine for a bit. I don't have any check engine light. Any tips would be great!
Old Nov 5, 2014 | 06:34 PM
tmcalavy's Avatar
tmcalavy
Tune it up...plugs, wires, fuel and air filters and check the codes, they will lead you in the right direction. Never hurts to do a complete tuneup and fluid change (oil, transmission, differential, power steering and coolant) when you buy someone else's rig and make it your own.
Old Nov 5, 2014 | 11:51 PM
Mikeman's Avatar
Mikeman
Yep. Gotta make sure the basics are good before you start looking for problems. Unfortunately, most car owners who claim to maintain their cars are only good about changing the oil and washing it once in a while.
If it's been sitting for a while it could have bad gas. If the tuneup doesn't produce the desired results, I would run the tank nearly empty and put some fresh gas in. The gas doesn't have to be old to be bad, either. A co-worker of mine was asking me why her Explorer was running rough. I asked her if she just got gas from a different station. She had. I told her to run the tank down and get gas from her normal station. She did and problem solved.
Old Nov 6, 2014 | 08:54 AM
nickmobile67
Thanks guys. I actually put plugs, wires, a belt, and pulleys on it last night. This morning going to work it seemed fine again, knock on wood. The plugs were pretty worn and the wires were starting to feel brittle.
Old Nov 7, 2014 | 08:44 AM
rasmith3530's Avatar
rasmith3530
I would also replace out the fuel filter. Per the mileage, this truck sat a lot.
Old Nov 7, 2014 | 09:18 AM
nickmobile67
I actually bought a fuel and air filter also, but when I went to change them I could see the dealer must have just put them on there.
Sissylala
May 2, 2019 10:43 AM
reed1951
Aug 21, 2010 09:22 PM
FTE Trigger
2004 - 2008 F150
Jul 17, 2009 11:26 PM
livisdaddyf150
1997 - 2003 F150
Mar 22, 2008 02:06 AM
markfh11q
Aug 29, 2007 04:51 PM
