MAX AC blowing only cold air
Old Jul 16, 2003 | 08:47 PM
TLAM's Avatar
TLAM
Question MAX AC blowing only cold air
I've just purchased a new 03' Expedition XLT. I've noticed that when I select MAX AC (which circulates only interior air) it only blows cold air, even when I turn it to Heat. I know this may sound stupid however, in all my other vehicles, including a cheap Focus rental, that if I selected MAX AC and turned it to Heat, that it would still close off the exterior air and recirculate interior warm air. I use this in the winter months if I'm stuck behind some foul-smelling vehicle so I don't have to smell it. My question is: does this expensive SUV not have the same feature that many other vehicles do? even cheap bottom-trim line Focus'?? Thanks for your time
TLAM
Old Jul 18, 2003 | 01:40 AM
steve83's Avatar
steve83
It probably engages the compressor anytime you set it to MAX, and it may have been cooling more than the heater was heating. How cold was the outside air? How long had the engine been running?
Old Aug 13, 2003 | 07:02 PM
TLAM's Avatar
TLAM
the outside temp has been around 90 (summer time). I talked to Ford Consumer Center (800-392-FORD) and even he said that I should be able to adjust the temperature with Max-AC selected. Thanks for the reply.
Old Aug 13, 2003 | 07:05 PM
TLAM's Avatar
TLAM
Hey you 03 Expedition XLT owners, are ya'll having the same problems??? Are you able to adjust the temperature while Max-AC is selected?? Or does it just keep on blowing cold air??
Old Aug 13, 2003 | 09:48 PM
HomerWinzlow's Avatar
HomerWinzlow
I posted this in the other thread you inquired about this. It has a water control valve that cuts off hot water to the heater core in MAX. You can over ride it if you want in the winter by placing a plug in the vacuum connector at the water valve.
92will
Oct 5, 2016 06:25 AM
Big Norm
1997 - 2003 F150
Sep 16, 2013 09:53 PM
xplorerboy
Jul 1, 2009 04:42 AM
Enduroman
Oct 8, 2008 02:30 PM
QuadVan
15
Jan 16, 2005 04:58 PM
