91 F-150 fuel filter
Your '91 was made before they went to the style that required any special tools. Pull the old clips out with a screw driver, pull the filter out of the bracket, pull the lines off, install new clips that should be with the filter, the lines will then "click" onto the new filter, put it in the bracket, and your done. Once you have done it once and see how it works, it will never take you more than 30 seconds to do it again.
