Ignition problems
Old Oct 28, 2014 | 09:58 AM
Matt5324's Avatar
Matt5324
Ignition problems
Hi guys, I've got a 1972 factory highboy that's having some starting issues. I turn the key and nothing happens. I disconnected the starter and when it is touched directly to the battery it works. I also replaced the starter solenoid. I know trucks of those years didn't have ignition modules and the voltage regulator shouldn't be an issue since that mainly regulates the alternator-to-battery power. Any input?? Any new place to start would be appreciated
Old Oct 28, 2014 | 10:30 AM
Gembone's Avatar
Gembone
check to see if you are getting power to the solenoid from the ignition switch. The ignition switches in these trucks seem to have issues if it's the original style.
Old Oct 28, 2014 | 12:39 PM
orich's Avatar
orich
I'd check that even if the solenoid may click while Turning the ign key to start position the voltage may not be going through the starter cable..
Test with a test light or volt meter..
Orich
Tonto Kowalski
Feb 2, 2022 08:06 PM
Toakley123
16
Oct 15, 2016 06:53 AM
pittdog1977
Jul 11, 2014 05:11 PM
nothercrash
17
Nov 25, 2012 11:44 PM
FLORIDABRONC
1978 - 1996 Big Bronco
Aug 24, 2004 01:56 PM
