transmission issue??
Old Oct 27, 2014 | 08:12 AM
akpolaris's Avatar
akpolaris
I have a 97 7.3 ltr F-350. It has approx 180,000 miles on it. In the 35 mph range the is a hissing or sound like a vacuum problem that occurs. I haven't noticed this at higher speeds. Is there a vacuum or some kind of shift assist for this gear range? The transmission was gone thru by a transmission shop about 1500 miles back. thanks
Old Oct 27, 2014 | 08:20 AM
farmert's Avatar
farmert
I'd be more inclined to say the hissing you hear is from a bad hose or connection to the climate controls. They run off the vacuum pump. The manual trannys have No vacuum connections, and I don't think the autos do either, as they are shifted electronically.
Old Oct 27, 2014 | 08:31 AM
akpolaris's Avatar
akpolaris
Oh my bad it is an automatic tranny
Old Oct 27, 2014 | 08:34 AM
madpogue's Avatar
madpogue
Keep in mind that there is no engine vacuum. What you're probably hearing is the exhaust back pressure valve closing. Do you notice a loss in power when this happens? Do you happen to notice that the noise subsides when you mash the go-pedal to the floor? Does it stop happening after the engine is warmed up?
Old Oct 27, 2014 | 08:38 AM
akpolaris's Avatar
akpolaris
There is no muffler on the truck and I think it is worse when it is cold. I do not have access to the truck right now because I am away from home working.
Old Oct 27, 2014 | 08:47 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
There is a valve on the turbo that closes to help warm up in cold conditions. You should be able to hear the hiss while parked as well. The purpose if it is to create back pressure to make the motor work a little harder. Even at idle you should be able to hear it a bit.
nddragon01
2004 - 2008 F150
27
Jan 25, 2018 09:23 PM
dagray3
Dec 26, 2007 01:21 PM
ivorycruncher
May 19, 2007 12:01 AM
FordandSkeeter
Jan 28, 2005 09:03 AM
