Rocker arms
Old Jul 16, 2003 | 03:29 PM
mpmitche's Avatar
mpmitche
Question Rocker arms
What is the stock ratio on a 302 and would it be worth the money to upgrade to roller rocker arms with a larger ratio (i see 1.6 quite often) if so is this a simple switch or more complecated
Old Jul 16, 2003 | 07:53 PM
jeff967's Avatar
jeff967
Rocker arms
The stock ratio is 1.6. Your money would probably be better spent elsewhere if you are looking for more power(heads, exhaust, gears etc.).
Old Jul 18, 2003 | 01:16 PM
jimandmandy's Avatar
jimandmandy
Rocker arms
Gears are probably what you need with 31" tires. 1.7 ratio rockers will work because a '95 has MAF, but your valve covers will have to be modified to clear them.
Jim
