Blue7.3 ,I did a lot off the work myself but my business takes me away a lot so I gave it to a mate who owns his own shop . He fitted the parts I orderd from the USA for me as I was on a dead line . But happy all good now... Thanks once again for your input ....any ideas about the tuner ???
Okay that's alright just trying to find out if you have just brought it from someone else and it was still locked.
Have you tried disconnecting both batteries for 15-20 minutes and retry the programmer?
It may just need to be reset.
Did you put it back to stock before you removed the PCM?
No don't take it to the dealers , someone will be able to help you so you don't have to keep throwing money at your truck.
I may be barking up the wrong tree but it sounds like the tuner is
trying to backup the existing tune from the truck and cant because
it has no room as its onboard memory already has a backup stored
from a previouse tune change.
Is there some way to dump whatever the thing has stored, or
some button to reset the thing to factory default?
One thing. Did you have the doors closed and the windows up when trying to change the tunes. I have know experience with Diablo but just try it. And what ever you do dont take it to a dealer
