Fuse box placement
Old Oct 25, 2014 | 03:35 PM
ige1963's Avatar
ige1963
Fuse box placement
I will be rewiring my '63 soon and was thinking about where to place the fuse box. I'm afraid if I put it on the side of the cab,under the dash it will get kicked and possibly damaged. It was suggested to me that I could put it under the hood, perhaps mounted on the firewall where it would be easy to access.
I'd like the thoughts of forum members on that please.
Old Oct 25, 2014 | 06:26 PM
P38fighter's Avatar
P38fighter
Box under dash on firewall.
I mounted it here on a plate I made. All the wiring was accomplished without the seats in the truck and without the instrument cluster in place. It went fairly smoothly. This is a Ron Francis kit.
Old Oct 25, 2014 | 07:39 PM
Jack605's Avatar
Jack605
Up high next to where the wires penetrate the firewall, if you kick it you have huge feet
Old Oct 26, 2014 | 11:32 AM
66f100project's Avatar
66f100project
Nah, it won't get damaged under the dash.
Keep in mind you won't have to worry about replacing a fuse if everything is wired up correctly to begin with. They last a long time as long as you don't overload the circuit. I realize it probably seems like the "brain" of your wiring project, and you feel like you need to "see it" at all times right now, but after you complete the project it's more like out of sight, out of mind.
Old Nov 3, 2014 | 07:20 PM
ige1963's Avatar
ige1963
Under Hood?
So, any opinions about putting the fuse box on the firewall under the hood. Is that a bad idea?
Old Nov 3, 2014 | 09:57 PM
TxStang2010's Avatar
TxStang2010
newer cars have them under the hood so why not ... just make sure its protected from the elements
Psyclopse
May 19, 2018 05:30 PM
alans77crew
Jan 4, 2018 02:58 PM
rbtom
Jan 2, 2015 05:50 PM
daan-o
Feb 8, 2011 06:58 AM
dantsg
Electrical Systems/Wiring
Apr 2, 2008 08:19 PM
