1978 - 1996 Big Bronco
engine conversion
Old Jul 16, 2003 | 01:47 PM
broncorule's Avatar
broncorule
engine conversion
i have a 86 lincoln continental with a bad 302 and i want to convert it to a 351m what will i need to make the swap
Old Jul 16, 2003 | 02:18 PM
Big Red Bronco's Avatar
Big Red Bronco
engine conversion
hmmm, first would be finding a Lincoln website.
Second, is buy a Bronco and dump the Lincoln
Bruce (Big Red Bronco)
Old Jul 16, 2003 | 04:00 PM
mrwizard's Avatar
mrwizard
engine conversion
You're going to have a difficult time dropping a 351M in there. You'd be much better off going with a 351W.
Old Jul 17, 2003 | 12:30 AM
ryanguglich's Avatar
ryanguglich
engine conversion
the 302 and the 351M have different motormounts and bellhousings, try stick to motors that were offered in the car from factory. (like a windsor)
a windsor will bolt up to mostly everything except you'll need to take the pullies and accessory bracketry because of the increased deckhight. (also the throttle linkages are different, but that's an easy fix) I don't think you'd have to upgrade your rad for an extra 51ci
Old Jul 17, 2003 | 10:27 AM
Kemicalburns's Avatar
Kemicalburns
engine conversion
also you might have some hood clearance issues. because the 351 might sit a bit higher at least they do when dropped into a fox body stang.
later
Old Jul 18, 2003 | 10:10 AM
broncorule's Avatar
broncorule
engine conversion
thanx
