Lighter Circuit
Old Oct 25, 2014 | 11:34 AM
sseebart's Avatar
sseebart
Lighter Circuit
I bought a nice laminated wiring diagram from Classic Car Wiring, but it doesn't include the two circuits I wanted to see most (wipers and lighter). My wiring is a rat's nest; the original lighter is not hooked up and there's no telling how it went together. I don't see a fuse for it in the headlamp switch--where else would I look? Also, does anyone know what amperage that circuit is rated for?
~Steve
Old Oct 25, 2014 | 01:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The lighter fuse (FEW-14429-A) is barrel shaped, threads into the backside of the lighter socket. T'other end of the fuse has a threaded stud that the wire pushes onto.
If the fuse is the factory installed original, it will have a hole in it. By sticking the end of a paper clip into the hole, the fuse can be reset unless it has failed.
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
MUSTANG'S ETC in Van Nuys CA has 3 = 818-787-7634.
WESLEY OBSOLETE PARTS in Liberty KY has 8 = 606-787-5293.
MILLER OBSOLETE PARTS in Binghamton NY has 10 = 607-722-5371.
Old Oct 25, 2014 | 03:06 PM
sseebart's Avatar
sseebart
Thanks, Bill. Do you have a picture of the beast? I'm pretty sure the socket in there is not original--nothing of that description attached to the back. I've got a chain-store replacement, would like to make sure the fuse will attach to it. Otherwise, I'll look into an in-line replacement.
~Steve
Old Oct 25, 2014 | 04:45 PM
NumberDummy
This is the only pic that shows to fuse.
The original lighter has its bezel (marked LIGHTER) made as part of the element.
The lighter **** & element is 15052, the socket is 15055, the fuse is 14429.
The element (15054) could be bought by itself, but the pic doesn't show it that way.
sparkkky
May 20, 2012 08:18 PM
materthegreater
Mar 16, 2012 09:05 AM
Monte Doenz
Mar 28, 2007 12:21 PM
iamaguy1357
Jul 24, 2004 01:55 AM
kms910
May 27, 2004 02:56 AM
