2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Driver Side Rear Door Leak
Old Oct 25, 2014 | 10:09 AM
david_jr's Avatar
david_jr
2008 Limited - had a heavy rain 2 nights ago over 2 inches on the overnight and last night when I got home from work my wife told me she thought she heard water in the rear door of the Expy. I went out to check it out and sure enough you could hear water sloshing around in it. Today I went out after much consternation googling how to get the rear door panel off and found there was 1/2 to 3/4 of a gallon of water in the bottom of the door! I had to take the speaker out to get to it and then used a towel to sop it up. What a major pain. It did smell a bit musty, but I am not sure if this was a one time event or if it has been doing it for a while. We have never noticed water in that window so I have no idea how the water got into the inside of the door. Anyone ever hear of this before? I know there is an old thread on the rear hatch, but I couldn't find anything like this with a search. TIA.
Old Oct 25, 2014 | 03:35 PM
alwaysfords41's Avatar
alwaysfords41
Your drains in the bottom of the door are plugged. Open the door, and look behind the weather stripping on the bottom of the door. There are little drain holes along the bottom edge. Use your fingers or a pipe cleaner to clean them out.
5 minute job. Very easy if you still have the door panel off, do it from the inside. You might have little plastic rectangles along the edge, these are just trim pieces covering the holes, you can flex them and pull them out.
Old Oct 25, 2014 | 04:21 PM
david_jr's Avatar
david_jr
I didn't realize there were drain holes in there. There was quit a bit of muck, like mud in there. Thanks for the tip. I didn't realize it was supposed to get water in the door.
Old Oct 25, 2014 | 10:27 PM
alwaysfords41
Well done. Easy fix. They do take on water but are supposed to drain.
jake00
2015 - 2020 F150
13
Dec 19, 2022 09:47 AM
eryoung
Jul 25, 2020 06:25 PM
reesestewww
Mar 25, 2018 01:51 PM
prez1967
Dec 15, 2012 10:40 AM
ecopeas
Oct 28, 2002 06:13 PM
