Weird gauge issue
Old Oct 24, 2014 | 05:54 PM
ZombiePopper's Avatar
ZombiePopper
Weird gauge issue
A couple of my gauges haven't worked since I got my 82, the oil pressure and alt gauges, so since I had some free time I decided to mess with them.
-I found that the alt gauge wire is unplugged, there's a wire with a round rubber boot around it and its a round female plug, where does it plug into on the alt?
-I also found that the oil pressure gauge is unplugged from the sending unit, so I plugged it back in and it works...kind of...
Before the gauge was dead (obviously), now when I turn the key on (motor not running) the gauge needle snaps past the "H" (high ), but when I start the truck the needle snaps past the "L" (low).
The needle doesn't move at all once it gets to H or L.
Anyone have any ideas why the needle is acting like this? I thought about the sending unit but wouldn't the gauge not work at all if it was a bad sender?
Thanks guys
Old Oct 24, 2014 | 06:25 PM
KsCop's Avatar
KsCop
In terms of the oil gauge, it sounds like you have an 'idiot light' sending unit and not the one for the gauge. The 'light' sending unit will do exactly like you described with the gauge.
Simple fix; replace the sending unit with the correct one.
In terms of the alternator, I'm not much help...
Old Oct 24, 2014 | 06:35 PM
ZombiePopper
I think you're on to something, I almost thought the wires were switched, but key on (motor off) needle to "H" which would be the idiot light is on and with the motor running the needle to "L" equals idiot light off...
If my thinking is correct
Old Oct 24, 2014 | 06:49 PM
Gary Lewis's Avatar
Gary Lewis
I think y'all from my native state are right on the oil pressure gauge. For the alternator, perhaps this will help.
Old Oct 24, 2014 | 06:56 PM
KsCop's Avatar
KsCop
I had the same issue with my '63 oil pressure gauge. I learned a few things from that..
Old Oct 24, 2014 | 07:42 PM
Franklin2's Avatar
Franklin2
Someone may have been swapping clusters around. You may have more problems than you realize if you had a idiot light cluster and it was swapped for a regular gauge cluster. Is it charging?
If it's charging, I would not worry about the charge gauge. When they are hooked up and working most barely move and give any useful info.
Old Oct 24, 2014 | 10:30 PM
ZombiePopper
Thanks for the diagram Gary it'll help sort me out.
Franklin the truck charges great I've even got several aftermarket add-on's never even cranks slow.
The gauges LOOK orig but you know how that is.
I've got several aftermarket gauges I'm going to hook up but I'd like to have the dash gauges at least semi-working even though they're basically useless for monitoring the motor.
Benningtonr
Dec 21, 2015 11:41 AM
gysgtbigdaddy
Electrical Systems/Wiring
Jul 11, 2014 08:42 AM
Roger T. Pipe
Aug 2, 2012 05:31 PM
gmoneyword
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
20
Oct 18, 2005 12:31 PM
Dog_Brains
Jun 28, 2001 11:37 PM
