brake help
Old 10-20-2014, 06:11 PM
derrickmauk1003's Avatar
derrickmauk1003
derrickmauk1003 is offline
brake help
1979 f250 4x4. Has a brake booster. I put new master cylinder on it and new brake lines. When I push the pedal it goes half way and then jumps to the floor. Brakes are weak. There is not much vacuum on the line to booster.
Old 10-20-2014, 10:55 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,318 Likes on 2,468 Posts
Well I'd ck the vacuum line connections from the intake manifold to the booster. Hoses dry rotted? And open vacuum ports?
Did you bench bleed the master cylinder properly?
Your power brake booster maybe bad too?
jrmwilson
09-04-2014 11:45 AM
dr cabela
1997-2006 Expedition & Navigator
12-06-2012 11:36 AM
ajsanteiro
31
11-13-2012 01:03 AM
LTCPipkin
Aerostar
10-28-2007 08:56 PM
White73390
11-15-2003 07:55 PM
Quick Reply: brake help
