Excursion with 2013 Platinum wheels
Old Oct 20, 2014 | 10:40 AM
Sporters445gt's Avatar
Sporters445gt
Hi all long time reader and 1st post :-),
Have a little issue when I installed my factory 13 Platinum F350 wheels on my Excursion ... 1st they sat way in due to the offset so I purchased 2.5" spacers/adapters . Went to install yesterday and noticed I will need to grind the factory stud for clearance no big deal for very little needs to be removed , I proceeded to finish 1 tire to ensure all would fit and what I found is the factory lugs with washers are too big to thread on all the way tapered style will go on but due to taper would have to go backward so the flat spot is seating on the wheel. Guess my ?? is do I need to replace with longer studs or can I run the Acorn/tapered backwards....?
thanks all for your help and time !
Old Oct 20, 2014 | 11:11 AM
Avitech's Avatar
Avitech
I say longer studs.
Old Oct 20, 2014 | 01:10 PM
WE3ZS's Avatar
WE3ZS
What spacers did you get? (link?)
How far too short are the spacer's stud threads? How far inside the nut is the end of the stud?
It does sound like longer studs may be in order.
Pics?
Old Oct 20, 2014 | 10:11 PM
Apocalypse's Avatar
Apocalypse
When I bought my spacers everything that I needed came with them. I just bolted everything together and then put the wheels on, no grinding or anything. Sounds like you ordered the wrong thing...
Old Oct 20, 2014 | 10:14 PM
Sporters445gt
https://store.performance-world.com/...uctCode=820170
this is the link they are 8x170 to 8x170
Old Oct 20, 2014 | 10:20 PM
Sporters445gt
The spacers fit fine its the factory 2013 lugs with the washers that don't have enough lug to burry ............ im thinking Ill just buy some offset wheels
Old Oct 20, 2014 | 11:11 PM
Bently_Coop's Avatar
Bently_Coop
What happen to the original lug nuts on the Excursion? Do those work?
Old Oct 20, 2014 | 11:17 PM
Sporters445gt
They are tapered/acorn so id have to turn them around to use them don't think I should for they have the washer because the rim is not steel
Old Oct 20, 2014 | 11:42 PM
Stewart_H's Avatar
Stewart_H
Bently asked about the original lug nuts, as in OEM. Those acorn/tapered style aren't what came on the Excursions from the factory.
Do you sill have the OEM lug nuts?
Stewart
Old Oct 20, 2014 | 11:55 PM
Apocalypse's Avatar
Apocalypse
Ok, one I would never ever ever ever ever ever..... ever run those spacers. and two the acorns go in the spacers themselves and the OEM lugs should go on the wheels with no issues. If there is a problem send those back, they're obviously not correct. Are they hubcentric? If not throw them in a box and send them back. Do they have all those holes for multiple vehicles? If so throw them in a box and send them back. Do they need modification to go on? If yes toss them in a box and send them back. If it's not 100% right DON'T USE THEM!
Old Oct 21, 2014 | 12:01 AM
Sporters445gt
No if the acorn lugs are not 04 Factory then I don't have the correct lugs . Bought it used and it had aftermarket wheels on it which must of been lug spef not hub .. Ill try a scrap yard tomorrow and see if the proper factory 04s !Thanks im thinking this is the issue !
Old Oct 21, 2014 | 12:05 AM
Stewart_H's Avatar
Stewart_H
They look like this:
...with a built in washer.
Ford Lug Nuts Lugs Nut 32 Pcs F250 F350 Excursion | eBay
Stewart
Old Oct 21, 2014 | 12:17 AM
Sporters445gt
Yes same lugs my 13 uses ... Not enough stud to thread it all the way ... The spacers were ordered by the Ford dealer and are made for the hubs not studs ... Also I know the acorns lugs that came with the kit bolt the spacers to the truck ...The wheels on the truck before I changed them to the 13 used the " acorn" style
Old Oct 21, 2014 | 12:20 AM
Sporters445gt
Made for 8x170 to 8x170 not mulptial fit ...
Old Oct 21, 2014 | 06:57 AM
Apocalypse's Avatar
Apocalypse
It says that but the picture shows several holes was my only concern.
