PCV Filter
Old Apr 12, 2002 | 06:52 PM
WB9PRG's Avatar
WB9PRG
PCV Filter
Is there a PCV filter on a 1996 f150 302 ??
I dont think so ..
The valve I have replaced several times.
Thanks,
Gene
Old Apr 12, 2002 | 07:59 PM
Pastmaster's Avatar
Pastmaster
PCV Filter
I think some places/people call the valve a filter.
'93 F-150 loaded and modified!
Check my Gallery
Old Apr 13, 2002 | 02:53 PM
stevieray's Avatar
stevieray
PCV Filter
There is a small auxilliary filter in the air filter box fpr the PCV system. It connects to a hose that goes to the driver side valve cover. If the PCV craps out this filter will get oil soaked and fall appart. It is available at most any parts store.
Old Apr 15, 2002 | 05:09 PM
beratte's Avatar
beratte
PCV Filter
No there's no filter on the 95 and 96 with the mass air sensor. I think the previous poster must have an earlier model.
Old Apr 16, 2002 | 07:45 PM
WB9PRG's Avatar
WB9PRG
PCV Filter
Thanks BERATTE,
I thought there was no PVC Filter.
I traced the one hose from the PCV valve, to the Upper manifold.
Also I traced the other hose from below the oil filler cap, to the mass air area.
The flow of air must be, from the mass air area, to the filler cap, through the crankcase, and up through the PCV valve, then into the upper manifold.
Thanks,
Gene
Old Apr 16, 2002 | 08:17 PM
MustangGT221's Avatar
MustangGT221
PCV Filter
Old Apr 16, 2002 | 10:49 PM
beratte's Avatar
beratte
PCV Filter
Yes, I agree with you on the routing. I replaced my PCV valve a few months ago and went on the same search you did and finally concluded there was no filter.
