Help with PID's?
I also noticed a pretty big difference on my longterm fuel trim from bank one to bank two. Bank one was typically twice the value of bank one. I'm guessing these should be close to equal?
Anyways any thoughts and advice on what I should be looking at/for would be much appreciated.
Thanks
JB
Set up the dashboard to display & record IAT, ECT, MAF, O2 sensors #1 for both cyl banks, long & short term fuel trim for both cyl banks, drive it & see if it finds anything out of normal.
If the O2 sensors have 75K or more miles on them, they belong on, or at the top of your suspect list, as their voltage switching range & speed get slow & lazy with age, sorta like me & that can cause the computer to corrupt fuel trim & turn in poor mpg.
If you've been running an oiled foam, or cotton gauze air filter, or have an ill fitting air filter, or improperly buttoned up filter air box, or an opening in the intake air tube, it can cause the MAF sensor to get dirty & corrupt its PID output to the computer about true air flow into the engine & that'll mess up fuel trim & affect mpg.
Dirty fuel injectors can affect mpg, as their spray pattern fuel droplets get course, we won't get a good spray pattern or a complete fuel burn & that'll cause a drop in mpg.
A dirty sticking open PCV valve, its loose rubber fittings, or dry rotted/cracked rubber tubing, can cause what amounts to an unmonitored vacuum leak, as its down stream of & not monitored by the MAF sensor, thus can corrupt fuel trim, but usually for both cyl banks.
Seeing as how you seem to have an unbalance of fuel trim in one cyl bank, concentrate for now on things that'll mess with fuel trim on that one bank, like the #1/upstream O2 sensor, or a vacuum leak, or leaky fuel injector. A plug read on the suspect cyl bank can give an idea whats going on inside each cyl & one with carbon fouled plugs, would suggest a fuel injector problem, like being dirty & having a runny nose.
Some beginning fuel trim trouble shooting thoughts for consideration, let us know what you find.
Are you thinking the thermostat is stuck open? I consider them maintenance items and change them every 2-3 years when I drain/fill the cooling system. Believe it or not, I've had one fail in less than 2 years and I use what I consider to be a decent brand (Stant). I've had OEM fail in 5 years. It's easy enough to change while I have the system drained and the cost is insignificant. Might be a good time to change yours if it's been a while.
Should my oxygen sensor voltages be the same on both banks or will they be different to each other due to being at different stages of combustion?
I also just noticed that my O2S_TEST notes an error, but O2S11F and O2S21F read no fault.
Long term fuel trim 1 is consistently above -20% and LONGFT2 is consistently below -10%.
Some other information to help, my PCV valve is brand new (replaced last week), my air filter is clean (it's not oiled), I've inspected my vac lines and they are all in good condition and I didn't notice anything loose or out of place. Truck is standard so that eliminates the OD inhibition.
I will pull my plugs tomorrow if I have time but I think I'm leaning toward O2 sensors.
O2 sensors.
Seeing as how we only have two upstream O2 sensors, one for each cyl bank, we are just seeing the average of all cyls on that bank, one cyl may be running lean, while another is running rich, but a plug read will tattle on how all cyls in a bank are doing. Now if we had O2 sensors for each cyl, all we'd have to do is look at the fuel trim numbers for a particular cyl to know how it was doing!!!!
Anyway if all things are equal & running ok, fuel trim for both cyl banks should be closely matched. Here is some good general TSB input *01-9-7***DRIVEABILITY - HO2S (HEATED OXYGEN SENSOR), CATALYST, AND FUEL SYSTEM MONITORS - SERVICE TIPS - OBD II VEHICLES ONLY
Let us know how the plug read goes.
BTW, how many miles on these O2 sensors????
EDIT: Here is a fuel trim mini-tutorial. http://www.aa1car.com/library/what_is_fuel_trim.htm
