2wd to 4wd switch
Old Jul 16, 2003 | 06:37 AM
djclass22's Avatar
djclass22
2wd to 4wd switch
Ok guys, I know this topic has been bled dry on more than one occasion but bare with me for a sec here. I got a 1992 ford f 350 dually that I REALLY want to convert to a 4 WD 4x4. I plan on finding a doaner truck that rolled or something and just take all the 4x4 components off of it and use them on mine but does anyone know of any problems or tricks I should know about before I start this project??
For example, mechanical parts are mechanical parts and will work when installed right but will I need to get a diffrent computer for this conversion? Keep in mind I don't believe in automatic locking hubs so I'll be using a set of Warn mechanicals.
Thanks!!
Jay
Old Jul 16, 2003 | 03:56 PM
janiceranger's Avatar
janiceranger
Cool 2wd to 4wd switch
I am doing this right now. Some of the Information I recieved was not right. It is different and time consuming. I am doing this in 2 stages. transmission and transfer case (adding a Overdrive from US gear). It is a standard transmission.
I can give you a play by play.
Mine is standard. Yours?
thanks
Old Jul 16, 2003 | 04:46 PM
djclass22's Avatar
djclass22
2wd to 4wd switch
Mine is an automatic but I was going to see how bad it would be to convert to a standard along with the transfer case...
I might be pushing my luck...lol
Old Jul 16, 2003 | 04:57 PM
janiceranger
2wd to 4wd switch
It is not too bad of a job. If you want, I can e mail you pictures as it goes. This is ONLY IF you are serious about it.
Old Jul 16, 2003 | 06:18 PM
MustangGT221's Avatar
MustangGT221
2wd to 4wd switch
It's pretty straight forward, gut the suspension in the front of your truck. Mount the leaf spring brackets, leaf springs, mount the D60 axle, track bar if it has one (not sure), mount the steering, change the tailshaft on the transmission, move the crossmember back and bolt it up to the BW 13-56 transfer case, connect the driveshaft and away you go. Thats the basics. You'll need a new driveshaft too.
Old Jul 16, 2003 | 10:39 PM
janiceranger
Thumbs down 2wd to 4wd switch
if it was only that easy.
If i was not in the middle of it I would buy that.
black98f1504x4
Offroad & 4x4
Jun 28, 2013 04:24 PM
khadma
19
Nov 18, 2011 07:23 AM
Randy8876
Mar 2, 2009 11:31 PM
majesady
Sep 24, 2002 05:08 PM
WrenchHead84
18
Sep 19, 2002 04:26 PM
