I beam pivot bushings
I replaced the I beam bushings the other day and I cannot believe the difference in how the truck tracks, handles, and drives. This was on my 93 f150 4x4. They were the last items on the front suspension I replaced, the least expensive, and the most beneficial for this truck. I used a ball joint press with the axles left in the truck and it wasn't a bad job. Damn near like a new truck!
You and me both! When I tore mine apart, one of the bushings was so far gone that the metal sleeve in the center had worn thru the steel outer casing and was actually wearing down a spot in the axle housing itself! I sparked up my trusty Lincoln and built the damaged area back up, hit it with the Dremel to bring it back into a circle shape, then pressed in new bushings. Went for a ride and was amazed at how much better she handled! Felt like driving a brand new truck!
As for doing it under the truck... I gave up and pulled mine out because it wasn't worth the frustration of doing it under the truck. I mean it ain't no thing to pull the shock and spring bolts and yank the calipers. Everything else was disconnected anyway.
guys forgive me if im asking a dumb question , but i have a 95 250 with the ifs up front. is this what the OP and the above coments are about. if so can yall recomed the best bushings, or a full rebuild kit? shes like driving a school bus right now and bad when i hit a bump.
Best bushings would be poly ones instead of rubber, but I'm not sure what's available. I just bought the best ones AutoZone had (I know... ) and put them in, they're just plain rubber or whatever.
A full rebuild would just be replacing the pivot bushings, radius arm bushings, coil spring isolators, shock absorber bushings, sway bar bushings, etc. Basically anything rubber. Not sure if all the parts are available in a kit or not, but you might have a look over at Jeff's Bronco Graveyard and see if he sells anything like that as a kit.
Rusty_S
19
10-18-2015 08:02 PM
