4x4 conversion question
Old Oct 19, 2014 | 02:21 PM
Monte1go's Avatar
Monte1go
My brother just gave me a 91 F250 4x4 with a blown motor. The only things worth salvaging on the truck are the axles and transmission. Can I use the axles and suspension on my 86 F150?
Old Oct 19, 2014 | 02:58 PM
Franklin2's Avatar
Franklin2
No, they will not fit. You could put your f150 body on that frame. That would be a bolt-on deal if it's the same wheelbase. But then you need a engine. Don't know what you have in each truck to see if they are swappable.
Old Oct 19, 2014 | 03:50 PM
Monte1go's Avatar
Monte1go
What would I have to do to make them fit?
Old Oct 19, 2014 | 04:17 PM
Franklin2's Avatar
Franklin2
Use the f250 frame. The f250 front axle is made for leaf springs, your f150 has coils. The f250 front axles are shorter, so you would have to custom mount the pivot brackets for the frontend. What a mess. Nothing will bolt up and work except maybe the rearend. And in the end you have the f250 running gear on the lighter f150 frame.
Jorp
18
Dec 22, 2010 06:54 PM
Caveman84
Dec 19, 2009 05:01 AM
79460ME
Jan 16, 2009 04:13 AM
sphinx
Feb 15, 2008 10:32 PM
lance65
Jan 9, 2007 08:45 PM
