Offroad & 4x4
tires too big?
Old Jul 15, 2003 | 11:11 PM
motorheadmach1's Avatar
motorheadmach1
tires too big?
ok so i put a set of 33x12.50's on my stock 15" rims. i have an 86 150 4x4 and as i figured they rub the radius arm. any suggestions as what to do to fix this. i was thinking i could handle a little rub but it touches sooner than i thought it would. they look real good on the truck withotu a lift i dont want to take them off.
Old Jul 16, 2003 | 12:31 AM
mrwizard's Avatar
mrwizard
tires too big?
12.50's are much to big to be on the factory sized wheels. Yes, I know they fit but all manufacturers I've seen recommend a minimum of an 8.5" wide wheel. Look into getting some wider rims with maybe just a bit less backspacing than the factory ones.
Old Jul 16, 2003 | 01:08 AM
motorheadmach1
tires too big?
yeah you rnot supposed to mount on a wheel anythign more than 4" skinner than the tire i was wondering if anyone used those wheel spacers that you bolt on and they give you new studs adn like an inch of spacing
Old Jul 16, 2003 | 11:16 AM
bronczilla's Avatar
bronczilla
tires too big?
Backspacing or spacers
Old Jul 17, 2003 | 09:16 AM
Menroid's Avatar
Menroid
tires too big?
I had an 86 with the same size tires but I had 10" wide wheels and I had no problems with any scrubbing.
