still stalling
Old Oct 16, 2014 | 07:45 PM
mattb77's Avatar
mattb77
still stalling
Posted recently that my 87 f350 stalls. The reply I was mostly centered around the tank pick up tubes and foot. So I filled the tank bled got the air out of the lines as far as the filter. If I press the bleeder nozzle above the filter it shoots out fuel no air. Looking at the injector pump the very top just off center left line is dripping a drop every 3 to 5 seconds and it's wet on the top of the line above the cylinder passenger side rear that is all I can see but there may be more. So the question is that enough to make her stall? She will idle fine just when I try to drive. About to order o rings to put in lines but what are the chances of not breaking the lines or they not being rusted so bad I have to buy all new ones?
Old Oct 18, 2014 | 07:11 PM
KimbroZz's Avatar
KimbroZz
im curious about this as well. how old is your injector pump?fuel pump? possibly the fuel pump not being able to keep up with the injector pump? bc u said that at idle it's fine but when u drive it it stalls. j
Old Oct 31, 2014 | 11:50 AM
mattb77's Avatar
mattb77
think i got it
so it seems like the fuel pump was no good just had it changed 2 years ago with only 10k put on it but seems like it worked
Old Oct 31, 2014 | 06:52 PM
RBerry9511's Avatar
RBerry9511
It could be a problem with you check valve letting you lose prime. Mine had that problem and the tank selector valve was letting air in the system and the symptoms were the same. I am by no means a guru but I bypassed he tank selector valve and pu a check valve in between the lift pump and the filter head.....I hope it helps.
oldbird1965
21
Mar 9, 2018 02:39 PM
3000gtman
16
Feb 9, 2017 12:22 AM
mark's1984
Mar 25, 2016 05:23 PM
craigm126
Apr 3, 2013 10:00 AM
79supercab4x4
Jan 3, 2002 01:02 AM
