ECZ-B Heads ?
ECZ-B Heads ?
Hi,
I am working with the following 1964 F100 2wd 292 Y block stock. I pulled out the engine this weekend and picked up a set of ECZ-C heads and a ECZ-9425-B intake. My question is with the heads are these pretty much bolt on can you run the same rocker assemblies and pushrods? Anything else I should be aware of? This is our first Y block.
Any help greatly appreciated
Thank you
Thank you
The pushrods are different for the C heads but you may still be able to use the old ones. Otherwise, it should be pretty straight forward.
You might also notice that the ports are smaller on the C heads. This is not a big deal. They actually should perform about the same.
Thanks for your help and I see my title is wrong should be ECZ-C heads.
Justin Braun
10-22-2017 09:47 PM
f100guy
09-08-2004 04:04 PM
atticmole
01-19-2004 05:11 PM
Ratsmoker
16
05-07-2001 07:35 AM
