1998 brake lights not working
Brake lights do not work.
The turn signals work, the flashers work, and the running lights (head lights) work. I checked the bulbs and both filaments light up during the above processes.
I removed the brake switch at the pedal. When I was removing it, I heard some clicking under the dash. I connected the 2 pins with a wire (bypassing the switch), and got a spark a few times along with the clicking sound like a relay,and the brake lights would come on, but now nothing. No sparks, no clicking. The flashers and turn signals and running lights still work.
There are no blown fuses in the fuse box to the left of the steering column.
Is there a relay somewhere under the dash just for the brake lights?
Any clues?
Any clues?
This truck doesn't have one. If it does, it must have been bypassed.
If an automatic, can you shift from PARK to any gear with the ignition in RUN without stepping on the brake? If no, then you have the interlock. If yes, it's not working and you do have a safety issue. Don't leave pets or kids in in the car unattended as ll they have to do is pull or push down on the shift lever and it's no longer in PARK.
If that solenoid goes bad, will it stop the signal going to the rear lights?
Where is it located?
You are now at the point where a multimeter and some one who knows how to use it are needed.
russell christy
09-26-2013 06:27 AM
81fordf150ranger
10-22-2011 04:17 PM
brseidel
10-15-2010 08:31 AM
