Aerostar Ford Aerostar
A/c
Old Jul 15, 2003 | 09:53 PM
firedog007's Avatar
firedog007
A/c
Does anyone know what it takes to replace the pressure switch on a 1994 Arrowstar 4.0L? I found that the pressure switch is falty by trouble shooting the system. I pulled the wires off and jumped them and the clutch engaged.
Any help would be great.
Thank you.
Mike
Old Jul 15, 2003 | 09:56 PM
GR8Diesel's Avatar
GR8Diesel
A/c
Are you sure the switch is bad? It could be preventing you from running with an undercharged system.
Old Jul 15, 2003 | 10:01 PM
firedog007's Avatar
firedog007
A/c
No the system is fully charged acording to the gage.
Old Jul 16, 2003 | 12:09 PM
reever's Avatar
reever
A/c
My '93 shorty's pressure switch is located on the Accumulator. When I replaced the Accumulator recently, the switch just unscrewed off of the fitting (schrader valve). Be aware that there is a small "captured" o-ring on the Accumulator fitting. When I removed the switch, the o-ring came off about half way with the switch. Don't lose the o-ring! The replacement that came with the Accumulator was the incorrect size and I had a leak. I reused the original o-ring and have no problems....to date!
reever
Old Jul 16, 2003 | 04:50 PM
firedog007's Avatar
firedog007
A/c
Does this require recharging the unit after changing the part?
Old Jul 17, 2003 | 09:16 AM
reever's Avatar
reever
A/c
"Dawg"
If your switch is on the Accumulator like mine, then no, you don't have to do a recharge. The fiting on the Accumulator has a Schrader Valve in it (like a bicycle tire). The valve isn't depressed until the Switch is screwed on completely. Don't forget about the O-ring!
reever
