Engine oil pan gasket
Old Oct 10, 2014 | 10:44 AM
Snuggyworm's Avatar
Snuggyworm
Guys,
It's been a while since I posted. I think my oil pan gasket is probably shot to hell. Anyway, I was thinking of changing it out. What's the best and most efficient way to do it?
Thanks in advance,
Dom
Sent from my iPhone using IB AutoGroup
Old Oct 10, 2014 | 10:52 AM
r2millers's Avatar
r2millers
Pan gaskets don't usually go bad by themselves. Have you torqued your pan bolts recently?
I bet you'll have to lift up your engine to accomplish.
Old Oct 10, 2014 | 11:31 AM
Snuggyworm's Avatar
Snuggyworm
Originally Posted by r2millers
Pan gaskets don't usually go bad by themselves. Have you torqued your pan bolts recently? I bet you'll have to lift up your engine to accomplish.
Yep. I tightened them yesterday. Some were loose. Today is just 2 drops on the ground. Is the torque setting about 10 ft lbs?
Thanks,
Dom
Old Oct 10, 2014 | 11:41 AM
69cj's Avatar
69cj
Two drops? It's possible that you just squeezed out some oil between the gasket and pan or bedplate. I'd hit it with some brake or engine cleaner, hose it off and see if it continues to drip before I jumped to conclusions.
Old Oct 10, 2014 | 01:32 PM
r2millers's Avatar
r2millers
Thanks,
Dom
89 inch lbs or about 7.5 ft lbs. since it's an old gasket, more just a pinch more like 8-9, carefully.
Old Oct 10, 2014 | 10:43 PM
Ford_Fan1's Avatar
Ford_Fan1
Are you sure its not a bedplate leak?
Old Oct 21, 2014 | 07:53 AM
Snuggyworm's Avatar
Snuggyworm
Thanks guys for ur input. Might be bed plate. I'll have to make time to check. Thanks!
gordo2
Sep 13, 2013 12:20 PM
mr.fordneck
Apr 17, 2012 11:01 AM
joeinmd
Jun 28, 2008 10:24 PM
ALL BOY
Jan 8, 2006 10:26 AM
mike9762
Apr 27, 2005 11:20 PM
