Sponsored by: Auxito
Airbag code 32
Old Jul 15, 2003 | 06:37 PM
rcook221's Avatar
rcook221
Question Airbag code 32
I have a 1999 F-150 that is giving an error code 32 (3 blinks then 2) on the airbag sensor. Does anyone know what this means? Is this something I can fix or do I need to take it to the dealer?
Is there any danger of the airbag deploying while my wife is driving it?
I am mechanically inclined and would appreciate any help.
Thanks in advance!
RC
Old Jul 15, 2003 | 08:40 PM
Racerguy's Avatar
Racerguy
Airbag code 32
Hi RC and welcome to FTE
A Light Flash Code 32 means the driver's airbag circuit resistance is too high. The most common problem that causes that is the clockspring in behind the steering wheel is bad. The clockspring is the piece that allows the steering wheel to rotate while keeping the electrical contacts between the steering wheel and the steering column connected.
To replace it you have to remove the steering wheel.
With the airbag light on or flashing the airbag system has been deactivated. It wont deploy whether or not your wife has an accident or not...tell her not to crash the truck until it's fixed
Old Jul 16, 2003 | 05:06 AM
rcook221's Avatar
rcook221
Airbag code 32
Thanks Racerguy!
Do yoy know where I can purchase a clockspring and about how much they cost?
Thanks again!
Old Jul 16, 2003 | 09:15 AM
Racerguy's Avatar
Racerguy
Airbag code 32
I doubt that anyone but your dealer will have one and I dont know what they sell for....I just install them
Old Jul 23, 2003 | 01:07 PM
rgbutler's Avatar
rgbutler
Airbag code 32
I have the same problem. Can you tell me how to locate this area so that I can try spraying contact cleaner on the surface? I believe that the cab had been rinsed with a hose many times by the previous owner and therefore corrosion could be built up. thanks
Old Jul 23, 2003 | 02:14 PM
Racerguy's Avatar
Racerguy
Airbag code 32
Hi rgbutler and welcome to FTE
The clockspring is right behind the steering wheel.
Usually it is broken inside.
