69 F100 Pulling power?
Old Oct 8, 2014 | 08:36 PM
WmBaldwin57's Avatar
WmBaldwin57
I have a 69 F100 with a 360 and I'm considering refurbishing it to use as tow vehicle. I'm considering a fairly large boat, say 4000-6,000 lbs. Does this truck have what it takes to pull 6,000 lbs out of the water or should I invest my money elsewhere? I don't want to sink a lot of money in this only to find it won't pull the boat out of the water.
Old Oct 8, 2014 | 08:45 PM
HIO Silver's Avatar
HIO Silver
An F250 is better.
Old Oct 8, 2014 | 09:09 PM
crazed87bronco's Avatar
crazed87bronco
The 360 will have the power to pull it no problem. but the 1/2 ton suspension/frame might be a burden. A f250 would be a better way to go but with some suspension mods in the f100 it should do alright.
Old Oct 8, 2014 | 09:21 PM
Alex from GA's Avatar
Alex from GA
It'll pull it fine but will it stop. An F250 has bigger brakes, suspension and a larger rear end. On some slippery ramps positraction comes in very handy. For many years I pulled a 5000 lb boat with my '68 CS with a cabover camper with no problem. I did build a good 390 for it. Total weight was 15000 lbs on a scale. I did have trailer brakes.
Old Oct 9, 2014 | 04:24 AM
jowilker's Avatar
jowilker
IMHO The F100 should pull your boat just fine. I don't know why you would need a F250 to tow with as you are not hauling it. My 66 F100 has had a power disc brake upgrade. I weighed it at a local feed store because I was so surprised how well it handled this big load. As shown 10,520 lbs total weight.
John
jjski78
May 9, 2011 07:32 PM
scruffythejanitor
23
Sep 14, 2010 09:11 AM
ASlowHurry
Dec 4, 2009 02:27 AM
jstandle
Oct 3, 2004 09:31 AM
krh427
Nov 19, 2003 10:01 AM
