Sponsored by: Kumho
Front brake calipers, rebuild or replace?
Old Oct 8, 2014 | 03:42 PM
LeoJr's Avatar
LeoJr
I've got one brake that is dragging harder than the other. The brake lines are about a year old.
I can get new piston seals and dust boots for about $7 each side, or remanufactured calipers for about $50 each side.
Either way will require a brake fluid bleed.
Anyone reseal their own and have thoughts on doing it again or not?
Old Oct 10, 2014 | 07:10 PM
Island Time's Avatar
Island Time
I just did the front brakes on my F150 and went with rebuilt. My reasoning was based upon prior experience from when I wrenched on my own cars in the 70's and early 80's. I always hated rebuilding calipers or wheel cylinders because the inside was invariably rusted (pre aluminum) or pitted from moisture and was a royal pain to get cleaned up enough to successfully rebuild.
I bought Motorcraft remanufactured calipers from rockauto.com for $36.79 plus shipping with a $40 core charge. I figured it wasn't worth the $20 bucks to deal with a possibly corroded bleed screw and rebuilding.
Edit to add: if you can afford the down time takes things apart to see what you need to order. In my case I couldn't so I also bought new retaining pins and anti-rattle clips just in case old ones were bad.
Unless they are in great shape with plenty of pad left, you might want to change your pads while you're in there. It's a lot easier now.
Also, check your rotors carefully to see if they are still serviceable.
Ham Gravy
May 28, 2018 01:06 PM
seagiant
Feb 21, 2017 05:22 AM
BlackTruckDave
Oct 19, 2016 12:23 PM
Tim Hodgson
Jan 14, 2015 06:34 AM
Jim in MI
Oct 31, 2007 10:10 PM
