Sponsored by: Real Truck
8" lift
Old Jul 15, 2003 | 05:02 PM
hobert's Avatar
hobert
Question 8" lift
I stoped at a car lot the other week with the truck, and looked at a used SD with a 8"pro-comp lift. I measured from the center of the front hub directly up to the bottom of the fender and came up with 30". I got home and measured my truck with my 4" and 3" combo, and came up with 31". Could someone with a 8" lift measure there's to compare. I'm going to need tires in the near future and was wondering what will fit.
Thanks Hobert
Old Jul 15, 2003 | 05:16 PM
Overkill's Avatar
Overkill
FTE *******
8" lift
Hobert,
Take a measurement from the top of your axle tube to the bottom of your frame rail (in the front) and I can give you a pretty good idea of what will clear. Theoretically you should have approximately 11.5". This with a 3" body should clear a 37/12.5 on 10s.
Old Jul 15, 2003 | 05:39 PM
hobert's Avatar
hobert
8" lift
I measured from the top of the axle tube between the front shocks to the frame where the bump stops bolt, and got exactly 12". I only have 8" wheels to keep them in the fenders, but I was figuring on trying a set of 37's.
Thanks again
hobert
Jun 19, 2003 03:52 PM
hobert
May 3, 2003 05:20 PM
hobert
Mar 6, 2003 02:16 PM
hobert
User Gallery & Picture Display
Jan 23, 2003 04:05 PM
hobert
Dec 4, 2002 09:14 PM
