Bondo Differences?
Old Oct 7, 2014 | 07:54 PM
Snipeston's Avatar
Snipeston
Bondo Differences?
Need to do a little filler work on some panels of a 1995 F150. Which product would be the best suited for filling some minor dents and dings?
Regular Bondo
Bondo Professional - states works better with galvanized body panels used on 1998 and later vehicles
Bondo Fiberglass Reinforced - states stronger than regular bondo
Thanks the help!
Old Oct 10, 2014 | 05:46 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Evercoat's Rage Gold will do what you need. It can be purchased at any local auto paint supplier or online and easy to work with. "Bondo" is a brand name I stay away from.
Old Oct 13, 2014 | 09:11 PM
TxStang2010's Avatar
TxStang2010
I use Rage Gold and Rage Extreme , best I have found .
Old Oct 17, 2014 | 02:28 PM
tbm3fan's Avatar
tbm3fan
Don't forget Rage Ultra which is really nice to work with. I rarely use Rage Gold when working with dents and dings that are shallow which is most of the time. As for generic bondo in the auto parts stores I wouldn't touch the stuff.
Old Oct 30, 2014 | 11:03 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Good info, thanks guys!
Old Nov 2, 2014 | 08:30 PM
joshs598's Avatar
joshs598
Try 3M Marson Platinum Plus Premium Gold Lightweight Filler - 01131.... I use to use rage but switch to 3M because i found the consistence to be the same as rage xtreme and depending what paint store you go to will be 10 to 20 dollars cheaper than rage....if your on a budget use evercoats lite weight filler it under 20 bucks for .8 gal.
Old Nov 15, 2014 | 03:34 PM
Snipeston's Avatar
Snipeston
Thanks for the info fellas
Aaron-71
22
Aug 19, 2010 01:35 PM
Magic
Paint & Bodywork
Dec 16, 2008 10:14 AM
bterry
Paint & Bodywork
Mar 12, 2006 04:18 PM
BoomerPower
Paint & Bodywork
Sep 6, 2004 12:14 AM
jmayer
Paint & Bodywork
24
Mar 18, 2004 12:38 PM
