I need some brainstorming help!
Old Oct 7, 2014 | 12:39 PM
xjpilot's Avatar
xjpilot
So I decided very last minute that I wanted to put a light bar on my truck, so I'm trying to get it installed before it gets painted. The problem is that the bar mounts don't sit flush with the roof. I can use some modified nylon spacers to take up that angle, so that's not the issue. What I can't figure out is how to make it so that the nutsert (or just a plain nut on the inside) sits flat, and doesn't follow the same contour of the roofline. Any ideas??
Old Oct 7, 2014 | 12:44 PM
Rusty_S's Avatar
Rusty_S
Only thing I could say is to use a nylon like spacer on the inside of the cab and cut it to fit the contour of the roof so the bolt will pull straight.
Ive seen these light bars before and they are very bright. I thought of going this route for my '82 when I install a roll bar. But I like the four round headlight bulb look more fitting for these.
Old Oct 7, 2014 | 02:51 PM
xjpilot's Avatar
xjpilot
I've thought about that too, the only issue is the double wall roof, it's not gonna be easy. Plus, I've got a headliner that's going in also, so it can't be thick. I also thought about having a metal spacer made, having it threaded and then welded to the roof
Old Oct 7, 2014 | 05:53 PM
Franklin2's Avatar
Franklin2
Most large lights/light bars are not mounted to the roof, they are mounted to braces/frames/roll bars that are mounted to the bed.
Does that light have a cover for it? It won't be legal on the street unless you cover it over with something.
Old Oct 7, 2014 | 06:23 PM
xjpilot's Avatar
xjpilot
I haven't had much luck finding a decent bar to mount it on, plus I'd rather not have have the bolts accessible, since these are quite commonly stolen. The cover is in the works, I still have a month or two to figure that out before it's on the road
Old Oct 7, 2014 | 07:51 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Dude, get yourself a stick of Epoxy putty.
Grease the bolt and use a flange nut.
Mix the putty and put a glob between the nut and roof.
Screw the bolt in (not too tight)
This will form a bed to correct the contour and also hold the nut in place.
Everything will be well supported and it will be easy to thread the bolts back in after the truck is painted.
Old Oct 7, 2014 | 08:44 PM
Rusty_S's Avatar
Rusty_S
Isnt that depending on the persons location?
Ive seen quite a few trucks at work coming in that has off road lights like I want to put on the roll bar I want and they just have plain open covers that allow light through but protects from damage. I am thinking its one of those things that here its street legal to have them with or without the cover that covers the light up.
Old Oct 7, 2014 | 08:57 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
There are height above road laws here.
If the lights are not on, LE will not have a problem at all.
Old Oct 7, 2014 | 09:16 PM
KsCop's Avatar
KsCop
I know on our patrol cars, the brackets wrap the drip rail and clamp on
If it were me, I'd make a bracket like that to span the roof and then mount the bar on that.
Old Oct 8, 2014 | 08:02 AM
CountryBumkin's Avatar
CountryBumkin
Take a hole-saw and cut a hole in the inner panel just below where the mounting bolts are. Then you can get to the fastener/washers coming through the outer panel (roof). I did this for my Sun Visor.
Cutting a round hole in the panel will not weaken it any, and the headliner will hide the hole. You could even make up a spacer if you want so the outer and inner panels both provide support.
I even used the opening to spray in some rust preventer - sound proofing stuff (which I believe also adds strength to the roof).
Old Oct 8, 2014 | 04:59 PM
Franklin2's Avatar
Franklin2
Certain applications you can get away with it. I have snowplow lights, they are above the height of the headlights, and they do not bother me or anyone else. If you have a service truck with some sort of lighting for the job they do, they will probably be alright too.
Any lighting like roll bar lighting has to be covered, even if they are off. They won't pass inspection and the cops will pull you over in a minute. Is this just a thing in my state? I am not sure.
Old Oct 8, 2014 | 06:48 PM
KsCop's Avatar
KsCop
Lights that aren't lit, aren't a problem. They don't need to be covered. In Kansas anyway.
There are lots of restrictions in KS on lighting and it's worth checking the law in your state.
Old Oct 8, 2014 | 07:06 PM
PatinaTruck's Avatar
PatinaTruck
How about some mounting towers from a cargo/bike system like Yakima or Thule? May have to modify them somehow, but they set pretty clean on a roofline.
Old Oct 9, 2014 | 07:07 AM
CountryBumkin
Ive installed those lights on patrol cars before - and the brackets are plenty strong. The question is can you get something that will fit your older truck.
If you want to go this route check out Whelen Replacement Strap Kits & Low Profile Mounting Kits - Whelen Engineering Automotive
Old Oct 9, 2014 | 09:10 AM
tazman79's Avatar
tazman79
i have a 86 f150 and she keeps over heating i have check the water pump and therma stat and i flushed the radiater and she still over heats what else can i do i have put alot into her already
