86 EFI CONVERSION
Old Oct 7, 2014 | 12:08 PM
86fn150's Avatar
86fn150
86 EFI CONVERSION
85 351 H.O 4BBL TO 95 351W EFI USING 95 351W AND FORD RACING HARNESS WITH STANG SENSORS ETC
Old Oct 7, 2014 | 06:05 PM
Franklin2's Avatar
Franklin2
Be sure you change your signature
Old Oct 8, 2014 | 06:27 AM
ZombiePopper's Avatar
ZombiePopper
That's awesome I'm considering doing this also,
If you don't mind me asking, how much $ do you have wrapped up in the swap so far?
Old Oct 8, 2014 | 08:12 AM
SVTDriver97's Avatar
SVTDriver97
I'd like to do this for my 460, but I gotta figure out how.
Old Oct 8, 2014 | 08:30 AM
Gary Lewis's Avatar
Gary Lewis
So, the question is: how much change is noticed? Power? MPG? Drivability? But it sure looks like a clean installation. Well done!
Old Oct 8, 2014 | 11:02 AM
86fn150's Avatar
86fn150
haven't done full tally yet but about $1200ish.got a 95 parts truck for free but the biggest one time expense was the ford racing harness $540.i wanted to start with a fresh harness(and wiring diagram etc) .I was looking at msd atomic EFI but too much money and wanted a system that i kinda knew and can get parts for at napa on a saturday.
i started the truck sunday and just about have all the teething problems sorted out.still have a belt alignment issue but will get rid of my smogpump delete pulley(belt walks forward on pulley) and use shorter belt.went for a run around the block and WAY happier with injection now.probably won't expect much different mpg on highway but better in town.did it mostly because carbs suck in winter .will update soon
Old Oct 8, 2014 | 04:31 PM
tempest411's Avatar
tempest411
Why on earth did you go with the module-on-the-distributor version for the ignition system when those have such a well documented high failure rate when compared to the later remotely mounted module system?
Old Oct 8, 2014 | 05:44 PM
86fn150's Avatar
86fn150
my 93 stang still has the original module on it and the new harness was way too wrapped up to redo/add to in that spot.worked out great for me.
Old Oct 13, 2014 | 10:58 AM
86fn150's Avatar
86fn150
EFI wiring ISSUE questions
robjs111
Ford Truck Parts for Sale
May 11, 2013 07:08 PM
4tl8ford
89
Sep 30, 2010 01:01 PM
kuzco
Oct 14, 2009 05:46 PM
76JDGREEN
Engine Swaps
Jul 21, 2006 02:32 AM
