95 F150 4x4 Diff's ?
Old Jul 15, 2003 | 03:37 PM
Brymstone's Avatar
Brymstone
Question 95 F150 4x4 Diff's ?
I just purchased a 95 Ford 150 XL 4X4, 5.0L, ATC, Manual Overdrive (mazda ? really ?), rear end and door plate tell me 3.55 limited slip rear, Ford 8.8. Truck's good and straight, engines clean, two small fluid weeps. One @ LH output seal rear diff, One @ tranny output seal to driveshaft.
That's not the problem though, I get a low pitched sound like binding/metal rubbing when I turn sharply to the right on pavement from the LH side of the truck. This sound is definitely from the rear of the vehicle, LH side. I'm wondering if it isn't in the diff itself (ie: the leak on the output), but it sounds like it comes from the tire.
I figure I should be hearing a bit of tire skid from a limited slip, not clearance problems somewhere.
At 125 km/h, the rev is at 2600-2700, would bigger tires help this gas sucking 5.0 ? Or at least get me more mileage per mouthful ?
Also, what front diff is in this truck ? Or where can I find the tag on the truck ?
Thanks for any help, much appreciated.
PAT
Old Jul 15, 2003 | 03:53 PM
whaynes's Avatar
whaynes
Usually if you hear that type of noise when turning, it is an indication of front wheel bearing issues. Since it is a new truck I would recommend servicing the hubs and bearings and check the front axle ujoints. You should also, with the wheel up be able to see if the hubs are "locked in", by spinning the wheel and watching the axle shaft.
If your tires are stock(235 75 15) you could probably go with a 31" and if you do a lot of hiqhway driving a 32" without too much harm(maybe some rubbing at lock to lock)
Your front diff should be a Dana 44 TTB and the gear ration will be the same as the year but with no L/S.
Old Jul 15, 2003 | 04:38 PM
MustangGT221's Avatar
MustangGT221
According to my formula for RPMs, (125 KM/H is 77.5mph right?) that would put you at 2500ish rpm at 77.5 mph with a 3.55 gear and 235/75/15 tires. Unless the gears have been changed and are not what the diff tag says. You shouldn't hear anything from the Limited Slip. Do you think you could sit in the back of the truck and listen more closely while someone drives to see if you can pin point where the sound is coming from? Keep safety in mind please.
Old Jul 15, 2003 | 05:45 PM
Brymstone's Avatar
Brymstone
Mustang - The revs sound right, but I'm concerned with the gas consumption at that number. I drive about 1000 km a week, and gas in Fort McMurray is anything but cheap. The noise is definitely in the rear, it sounds like a rub/grind somewhere during tight radius turns (turning at stop lights, parking lots, etc.) Kind of feels like a shudder. It feels a little inconsistent, I wonder if it isn't during a specific point in the axle's revolution ?
Could you also post that formula, so I could use it for tire selection ?
Thanks for the ideas.
Old Jul 15, 2003 | 07:10 PM
MustangGT221
Do you think it could be the clutches in the Limited slip binding? Maybe you should change the rear axle fluid and pour in some of the additive (called friction modifier).
Formula is: MPH X GEAR RATIO X 336 / TIRE SIZE * OD RATIO
Tires are usually a little under their rating, like my tires are 32/11.5/15s and are really 31.8" in diameter. Also, the mazda 5 speed has an overdrive ratio of .80. Are you going to install larger tires? If so, don't touch the gear ratio. If you plan on keeping the same size tires, you could swap from a 3.55 to a 3.08, but the cost to do that is expensive (atleast $450 for parts alone). I wonder if you actually have a 3.55 gear in there. Put a mark on the top of your rear driveshaft and jack up the rear tires so they are off the ground. Rotate the tire exactly 1 revolution and count how many times that chalk mark goes around. Does it go around 3 and 1/2 times? That will tell you if it's actually a 3.55 gear in there. You could also count the gear teeth but, this way is easier.
Old Jul 16, 2003 | 08:23 AM
Brymstone's Avatar
Brymstone
Stang - Noticed last night that the strange noises occur only under power, not coasting in tight radius turns.
If I use the same tires front and back can I just swap up to bigger tires without worrying about synchronizing with the front diff gears ? I know I need to change some stuff in the computer so I get the right speed and mileage and all that.
Thanks for the help
Old Jul 16, 2003 | 12:09 PM
mrwizard's Avatar
mrwizard
As long as the tires are the same front and back, your fine. It's very easy to re-calibrate the speedo.
Old Jul 16, 2003 | 12:20 PM
MustangGT221
What size tires do you have now? and what are you planning on going to?
Old Jul 16, 2003 | 01:06 PM
Brymstone's Avatar
Brymstone
The tires I have now are 235/75R15 Hankooks.
I would probably go with 31's just to take advantage of extra speed for all my revs. I do a lot of highway driving so road noise and handling are more important than tons of torque and stump tearing power.
Would I need to lift any to fit those underneath ? Only 2 extra inches in height I think.
CPUNeck
43
Dec 20, 2020 10:13 AM
95e150CW
20
Sep 26, 2016 10:27 AM
BigF350
6.7L Power Stroke Diesel
Feb 24, 2014 10:49 AM
rockcrawler_101
Vehicles for Sale
May 20, 2013 01:12 PM
sconut1
Mar 2, 2008 12:19 PM
