AC Help!!!
Old Oct 5, 2014 | 09:51 AM
dgreco49's Avatar
dgreco49
Exclamation AC Help!!!
I currently have an 03 E-350 7.3L Dually Ambulance. We just had the Vacuum Pump replaced by Ford, and the blower motor replaced by me. Somewhere in between these 2 repairs, the AC Started to only blow out of the defrost vents. It will not blow on anything else, regardless of where the selector is. I have tried to find a vacuum leak, and i only found 1 or 2 lines. Im hoping i dont have to tear apart this dash. If anyone has any insight, please let me know!
Old Oct 5, 2014 | 01:20 PM
projectSHO89's Avatar
projectSHO89
Verify
1) The pump is actually pumping.
2) A steady vacuum is being delivered to the front HVAC control head.
Old Oct 5, 2014 | 01:59 PM
dgreco49's Avatar
dgreco49
Smile Thanks for your reply...
I was able to get it fixed. Followed the lines through the engine compartment, found a vacuum line that had a hole in it, replaced it and kept going. There was a connector connecting the main line into a secondary line that goes through the firewall. The main had vacuum, but through the firewall somewhere, it lost it. I couldnt access the Secondary without taking the wheel well out and doing some extensive searching, so i bypassed the firewall, bought new hose, and went straight from the main line through the "dogbox" and then connected it to the other side of the firewall. It now works and blows out of the vents. Its amazing how one SMALL leak throws everything off...lol.
Old Oct 5, 2014 | 02:02 PM
dgreco49's Avatar
dgreco49
Courtesy of This Guy:
Truckie256
Apr 7, 2013 08:07 AM
ScotF150
Modular V10 (6.8l)
Jul 20, 2011 09:04 PM
PPrash
Aug 4, 2010 09:46 PM
jnjventure
Oct 21, 2009 11:49 AM
crazie0025
Oct 19, 2006 11:12 PM
