1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Brake Master Cylinder Question
Old Oct 4, 2014 | 10:42 AM
kjvforme's Avatar
kjvforme
I'm thinking it's time to upgrade my single master cylinder to a double. Would the 1968 Ford F100 double work in the 1962? I'm no ready financially to do the power brake swap, but want to be able to stop if I loose the front or back circuit. The 68 price isn't that bad, and my 223 engine would have a fit providing vacuum for the booster on power brakes.
Old Oct 6, 2014 | 06:46 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Dual master cylinders also require a Brake Pressure Differential Valve, that some people call a proportioning valve.
Old Oct 10, 2014 | 11:32 AM
kjvforme's Avatar
kjvforme
What would you recommend Bill
Old Oct 10, 2014 | 11:39 AM
NumberDummy
You need to speak with Dave (garbz2), he will know all the particulars.
Old Oct 22, 2014 | 12:08 PM
unibody4x4's Avatar
unibody4x4
I used a 73 f250 master cylinder in my 62. I also used the proportioning valve from the same truck. The master cylinder was a direct bolt in but required modification of the brake pedal pushrod.
chetspencer
31
Oct 12, 2012 07:31 AM
jxnslotcar
Sep 11, 2012 04:14 PM
Fordtruck51
Apr 29, 2012 10:46 PM
joditruck
Aug 14, 2007 08:37 AM
mwc4275
Aug 18, 2002 10:17 PM
