Sponsored by: Real Truck
Overkill...Tie Rod Question
Old Jul 15, 2003 | 12:11 PM
kehale's Avatar
kehale
I have a pretty decent size lift now (12" or so) and am going to be doing the ORU ram set up after the 25th (waiting for a steering box from Lee's).
Anyway, what is on your Excursion for a tie rod?
Doesn't look like the factory one.
I only wanna do the welding once and would rather not use the factory bar (my ends have 44k miles on them etc).
Any advice?
-T
Old Jul 15, 2003 | 02:06 PM
Overkill's Avatar
Overkill
FTE *******
Kehale,
I've got a custom straight tie rod with bigger ball joints. Now here is the problem.... I had to clearance my diff. cover to clear the tie rod. Even then I had to add steering stops to keep it from hitting. Fortunately I need them anyway to keep the tires from hitting the springs at full lock so it worked out well. I also had to open up the taper on the knuckles to accept the larger ball joints. It does look better than the stock bent tie rod with all the funky changes in diameter. <img src="http://www.websmileys.de/cool21.gif">
