89 F350 Steering Pulls When Moving
Had the truck aligned, and on the rack it's good. However, as soon as the wheels start moving, the wheels turn to the right and takes everything with it. Im certain the steering wheel, shaft and pitman arm are all in line with each other, as the wheels and steering wheel are straight when still. But as soon as I start moving it turns to the right. So something is making the wheel/front end/whatever turn to the right. Where should I start looking?
Should put it in the first post, but it's a 4x4. The only adjustments you can make are to the toe and centering the wheels. Caster and camber are built in at the factory. Not much to adjust, and kinda hard to mess up. Everything is straight and lined up when the steering wheel is straight.
Received 3,213 Likes
on
Kongerup
1999 to 2016 Super Duty
09-13-2020 09:26 PM
Treacy
03-15-2019 02:33 PM
F100Mann
20
09-10-2013 06:41 PM
918eva
07-26-2010 02:09 PM
