Sponsored by: Real Truck
Electric Window Problem
Old Jul 15, 2003 | 11:51 AM
dcrown's Avatar
dcrown
The driver's side window will go down, but will not go up. I have replaced the switch, the motor, and a solonoid......Still does not operate in the "up mode"!!!!!
Help..............
Old Jul 15, 2003 | 06:58 PM
99f350sd's Avatar
99f350sd
Electrical problem maybe a bad connector on the switch or broken wire. What truck? year?
Old Jul 16, 2003 | 10:15 AM
dcrown's Avatar
dcrown
Early '99 F-250 SD
Thank You Kindly
Old Jul 16, 2003 | 08:17 PM
99f350sd's Avatar
99f350sd
have you done continuity on the wires for up.. do you need colors I can get you them.
Does it have one touch? if it does the gem module is involved.
Old Jul 17, 2003 | 12:19 PM
dcrown's Avatar
dcrown
Thank You for who you are---
The switch is a "one touch"...........and yes, I would appreciate the colors..............
Old Jul 17, 2003 | 12:59 PM
99f350sd's Avatar
99f350sd
Well first of all there are two relay's to check
one touch dwn relay and acc delay relay....I'm thinkin the otd relay or the gem module.. I'll have to look at the wiring some more.
Old Jul 27, 2003 | 12:01 PM
dcrown's Avatar
dcrown
I am looking into the gem module as the culprit....I would appreciate the color code so I can verify that the gem module is the problem......$300.00 for the module from Ford
Thank You................
Old Jul 27, 2003 | 12:11 PM
99f350sd's Avatar
99f350sd
You really need the wiring diag email me and i'll try to send it to you
Dick
Old Jul 27, 2003 | 01:07 PM
superdutyspv's Avatar
superdutyspv
I had an issue with my drivers power window, but it turned out to be a simple issue with a piece of rubber being in the way. Perhaps that is your issue too!
Old Jul 27, 2003 | 08:44 PM
HomerWinzlow's Avatar
HomerWinzlow
I would check for a broken wire in the door jam in the rubber boot between the door and the jam.
Old Jul 28, 2003 | 09:51 PM
dcrown's Avatar
dcrown
Dick
Please e-mail the color code if you would................
Thank You.........
Old Jul 29, 2003 | 06:54 AM
99f350sd's Avatar
99f350sd
Go in my profile and email me I need your address I'll send you the diag
Old Aug 1, 2003 | 12:53 AM
dcrown's Avatar
dcrown
Thanks for hanging in there. I cannot e-mail you as I have not been a member long enough. I'm trying to post it to you through the websters.
Thank You Kindly.....................
Old Aug 1, 2003 | 07:42 AM
99f350sd's Avatar
99f350sd
rjt@surfglobal.net
Old Aug 2, 2003 | 02:46 AM
Faithful Old Road Dog's Avatar
Is your truck still under warranty? My wife's F250 SD window had problems. It was the weather stripping.
