1991 Ford F-150 - rear leaf springs
Old 10-02-2014, 11:01 AM
dfletcher's Avatar
dfletcher
dfletcher is offline
Trailering
My f150 custom needs some help with the rear end. I need it to be a bit beefier.
Can I swap out the rear leafs with that of an f250 from the same year?
It is 2wd.
Old 10-02-2014, 11:14 AM
GoinBoarding's Avatar
GoinBoarding
GoinBoarding is offline
Your truck has 2.5" wide leafs, and the f250 springs are 3" wide (don't have to be same year). You can swap to the wider springs. You'll need front and rear spring hangers as well as shackles. New eyelet bolts and bushings would be wise, and of course new u bolts.
I put new 1700lb springs with a little extra arch to them in my f150, and is amazing how much better she handles weight. Still half ton springs but my old set must have been very sacked out.. well worth it to put decent springs in. Coupled that with new cc844 front springs, poly sway bar bushings, and bilstein shocks all around, it's one sweet ride compared to the old parts.
Old 10-02-2014, 12:19 PM
ATS Junior's Avatar
ATS Junior
ATS Junior is offline
SPONSOR
Anything is possible with a little bit of swapping out parts, too time consuming in my eyes though.
Have you thought about just getting direct replacement Heavy Duty leaf springs? That way you take off your old, replace with new and you are on your way. Much easier and probably much cheaper because you're not swapping everything out.
-Junior
Old 10-02-2014, 12:59 PM
GoinBoarding
^^Yep that's better advice. ATS can get you what you need too.
Take a good look at your rear spring hangers, they almost all rot badly.
cgrocen
07-20-2019 03:20 PM
cowboyty
12-18-2006 01:25 AM
SwOkcOffRoader
03-22-2006 05:03 PM
OLD RED 82
01-15-2005 06:27 AM
65Jalopy
06-14-2004 12:51 AM
Quick Reply: 1991 Ford F-150 - rear leaf springs
