Sponsored by: Real Truck
GEM Not Recognized by IDS
Old Oct 1, 2014 | 09:49 PM
mjb965's Avatar
mjb965
Has anyone ever run across this issue when they tried to use the Ford IDS to change the Tire Size/Axle Ratio, parking brake chime, other features, or reprogram the GEM? This was attempted on a 99 Super Duty for training use. I've never seen this happen before. The GEM on this truck didn't display any obvious issues or problems. However, it won't take a reprogram or accept any information. I've reprogrammed the ABS/TCM module with the new tire size, and flashed the PCM without any problems.
I noticed that the information stored in the GEM was incorrect. It had wrong differential gear ratios, tire sizes, and tire revs/mil when I retrieved them.
Would this be due to corrosion, messed up GEM, or just a particular run of GEM's? (similar to early '96 Dodge RAM ECM's that lacked certain functionality and had some features that couldn't be changed until later model years)
Thanks in advance.
h20camper
Nov 30, 2025 08:45 PM
bigreentruck
May 22, 2017 11:14 PM
vburke
1983 - 2012 Ranger & B-Series
Oct 13, 2006 10:30 PM
dandep
Jun 23, 2005 10:00 PM
