Hydraulic Clutch problem
Old Sep 30, 2014 | 12:37 PM
mnstang67's Avatar
mnstang67
I have a 90 F 150 truck that was an automatic that was a 2 wheel drive, I swapped out the tranny and running gear from an 86 F 150 so now it's a 4 wheel drive with a manual tranny. I use the truck for plowing and the problem is that when it gets warmed up the clutch doesn't seem to fully disengage and shifting is a lot of grinding. Any thoughts? Is there some kind of adjustments on the hydraulic clutches.
Old Sep 30, 2014 | 10:35 PM
impish's Avatar
impish
Is the slave cylinder mounted within the bell housing? There is a special bleeding procedure published for that type of hydraulic clutch release. Fail to completely release is very often caused by air trapped in the line somewhere between the master cylinder and the slave. Instead of moving the throw-out bearing completely, the movement of oil is partly wasted by squeezing air. impish
Old Oct 18, 2014 | 01:10 PM
kyrdnk's Avatar
kyrdnk
What is the bleeding procedure if it mounted outside the bell housing?
enrgizerbunny
Sep 7, 2017 02:41 PM
75camper460
Oct 31, 2013 07:27 PM
jejdavis
Jul 22, 2011 06:56 PM
Paramedpete1996F250
Dec 11, 2008 07:43 PM
bennie
Jun 14, 2003 11:38 PM
