transmission options.
Old Sep 29, 2014 | 11:29 PM
Futzy's Avatar
Futzy
Hi. This is my first post. I recently purchased my 73 f250 camper special. It has an fe360, and a granny gear warner t-18. I have seen posts on automatic trannys swaps, but I was wondering if anyone has any ideas on an overdrive manual I can swap with minimal hassle.
Old Sep 29, 2014 | 11:54 PM
HIO Silver's Avatar
HIO Silver
Sure. A short-shaft Tremec TKO 500 or 600 can use the stock bell and linkage. Start saving about $3200 or whip out the plastic.
Old Sep 30, 2014 | 12:15 AM
19-F250-78's Avatar
19-F250-78
I vote for a t56 6 speed if you go with a 2wd manual. Same deal as the TKO just a bit more money.
Old Sep 30, 2014 | 08:05 AM
Futzy's Avatar
Futzy
used?
Any good used options?
Old Sep 30, 2014 | 08:40 AM
ShaneNP123's Avatar
ShaneNP123
I don't think there are any factory installed overdrive transmissions that will bolt up to an FE. You could try searching for a used GearVendors OD unit.
Old Oct 1, 2014 | 06:49 AM
19-F250-78's Avatar
19-F250-78
Your best bet would be a gear vendors. The bolt patterns on FE blocks don't fit OD transmissions without adapter plates.
Old Oct 1, 2014 | 04:56 PM
B_line66's Avatar
B_line66
Not sure where you are located but used Gear vender:
us gear vendor overdrive
Old Oct 1, 2014 | 05:10 PM
HIO Silver's Avatar
HIO Silver
I think the statement above is generalizing based on automatics...Manual trannies bolt to a bellhousing.. not the block.
For clarification, a Tremec TKO can bolt to the stock bell with no adapter plate (see the pic above!) but a short input shaft is required. An adapter plate is required between the bell and TKO if opting for a long shaft version.
Old Oct 2, 2014 | 10:14 PM
19-F250-78's Avatar
19-F250-78
Yes that is what I meant. For some reason I thought the OP was wanting to know about auto transmission swaps.
Old Oct 2, 2014 | 10:18 PM
desperado_18_2000's Avatar
desperado_18_2000
I've read that an NV4500 from a Dodge pickup (Gas engine) can be made to work with the top loader 4spd bell housing that came on the t18-t19 etc transmissions that came in these trucks.
If it is true, this is the goal I'm shooting for.
Old Oct 2, 2014 | 10:33 PM
85e150's Avatar
85e150
NV 4500 write up:
Installing the NV4500 Overdrive Transmission - Ford Trucks
Aftermarket supplier:
High-Impact NV4500 Conversion Listing
Old Oct 2, 2014 | 10:49 PM
85e150's Avatar
85e150
The Ford issued MTs, the Mazda and ZF, are integral bell transmissions. As such, no bolt 'em to FE without adapter.
Ford FE Transmission Adapters
Don't know if they make an FE adapter, but if you are really into "mine's bigger", here's your box:
Big-Time Gear Shifting - 4Wheel Off-Road
Old Oct 2, 2014 | 11:29 PM
HIO Silver's Avatar
HIO Silver
My post referred to the statement in bold above by 19-F250-78... which is an incorrect gross generalization.
Old Oct 2, 2014 | 11:42 PM
85e150's Avatar
85e150
I agree, but then you'd have to tag yourself for: "Manual trannies bolt to a bellhousing.. not the block."
Not all do.
Anyway, I think the OP has the full picture now with several options and many, many ways to spend his overdrive dollar.
Old Oct 3, 2014 | 12:03 AM
HIO Silver's Avatar
HIO Silver
Not all do.
10-4... it's all good.
Ford Tempo Fan
Jun 1, 2021 11:58 AM
stevos 77 f250
Feb 7, 2015 03:44 PM
firerescue9
Ford Truck Parts for Sale
Dec 11, 2012 07:49 PM
xjpilot
13
Aug 13, 2010 08:25 PM
