Died after rolling window down
Old Sep 29, 2014 | 11:26 PM
rrodriguez's Avatar
rrodriguez
my husband started the pick-up last night. it started up no problem. he rolled down the driver side window and the pick-up died. he tried to start it back up and nothing. It won't start at all. It has been running fine. No issues prior to this at all. What would cause this? We checked the battery connections, they are fine. It has a brand new battery in as well. It's a 2001.
Old Sep 29, 2014 | 11:43 PM
chris86924's Avatar
chris86924
A short Maybe? Check All the fuses.
Old Sep 30, 2014 | 12:30 AM
rrodriguez's Avatar
rrodriguez
checked all fuses.
Old Sep 30, 2014 | 07:03 AM
AllaboutMPG's Avatar
AllaboutMPG
Is the starter turning the engine over and it just won't run or is it not turning at all? When you turn the key on is the WAIT TO START light coming on?
Old Sep 30, 2014 | 10:21 AM
rrodriguez's Avatar
rrodriguez
Yes the "wait to start" does come on.
Old Sep 30, 2014 | 10:47 AM
69issofine's Avatar
69issofine
glow plug relay
Old Sep 30, 2014 | 11:38 AM
AllaboutMPG
Is the starter turning the engine over and it just won't run or is it not turning at all? If it is turning over but not starting yo could try unplugging the ICP connector Thanks Tugly for the picture. If it starts and runs normally the sensor may be bad.
It could be a bad CPS( cam position sensor) but they usually give some indication by way of the engine running rough or stuttering.
burgy
Jan 10, 2018 12:06 PM
tnwalker01
Jul 16, 2012 02:12 PM
bubbasz1
Jul 29, 2009 12:41 PM
Hacker Hydro
Oct 22, 2007 03:17 PM
desbyk
Jan 31, 2003 03:53 PM
